event structure, case structure, iteration number
Hi
I am trying one example about Event Structure from the book,  LabVIEW for Everyone: Graphical Programming Made Easy and Fun.
The example in the book looks like this:
The number of 'work done' equals 'iteration number'.
But when I build a Vi and try this example, I got this:
iteration number is two times the 'work done'.
I have attached my Vi. Does anybody know what's wrong with my Vi
Bing
(2,934 Views)
Most likely, your button is configured for the "wrong behavior".
The example your screenshot shows expect the button to be "latch when released".
I think your button is "switch when pressed"...
Norbert
Norbert
Expert: Geometry
(2,932 Views)
Accepted by topic author liubingxy
Both Activation and Deactivateion of the boolean causes Value Change events, but you only add 1 when it's activated. If you set the booleans mechanical action to Latch instead of Switch they should be the same.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,930 Views)
Thank you both! problem solved.
(2,925 Views)
