event structure state machine
The event structure subscribes to the registered events, if any of those happens it'll run. This includes the timeout event which'll auto generate after the wait time. I'd set 10 or 100 as fixed timeout to have a responsive program which still will be calm and wait for the events.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 18
(2,266 Views)
@rcote1 wrote:
Yes, that's what I did, but its the Timeout event that decides if its goig to be a 0 or -1 that the Timeout terminal takes. My question is, how does the timeout event gets notified of any event that need to be handled?
Why would the timeout case determine its own timeout?  That makes no sense to me.  The timeout should be determined based on what actions you are performing.  So it should be the button presses that determine the timeout.
Can you post some code so we can see where you are at?
Message 12 of 18
(2,258 Views)
Is there a way to prioritize the other events if they happen instead of the Timeout event. I use a Timeout of 0 and if there are other events I would like them to be handled first. That would truly simplify.
Message 13 of 18
(2,245 Views)
Producer/Consumer.  This thread is going down a path that is not following best practices.  Handling the events in the same loop as the state machine makes no sense to me.  Separate the two.
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
Message 14 of 18
(2,241 Views)
Here is my program.
Richard
Message 15 of 18
(2,230 Views)
If there is an event in the queue, the Timeout will not be selected.  The event that was queued up will run instead.  The given timeout is just how long the structure will wait for an event starting when the event structure was reached.  Events could be queued up before the event structure was reached.  If so, they will run, not the timeout.
Message 16 of 18
(2,227 Views)
You mean like the State Machine fundamental example?
It sounds like a valid design.
/Y
Qestit Systems
Message 17 of 18
(2,211 Views)
Using a Producer/Consumer design pattern with a queued state machine would make a lot more sense in this application.  There would be no chance of blocking the state machine.  Easier to extend.  Lots of pluses.
Kelly Bersch
Message 18 of 18
(2,202 Views)
