event structure - vi execution
For example i have attached screen shots of the 1st and 2nd event.
DO I also need to wire the tunnels of the shift registers which are getting data from the VI specific to that event?
DOes that make sense?
Message 11 of 15
(864 Views)
Thanks. That makes sense. I like to know the reason why I need to do something!
Message 12 of 15
(862 Views)
Those two events looks fine.
Of course you aren't going to wire from one shift register to the other if your plan for that event is to change the data being stored into the shift register.
Message 13 of 15
(861 Views)
Thought so just wanted to check. Smiley Embarassed
In the second event attached, I am still having the problem that whatever was in each of the controls when the vi opens be it 0's or actual values they are what is passed on rather than what the user inputs for that particular participant. DO u have any ideas?
Message 14 of 15
(858 Views)
Hi
coudl you remove 'Use default if unwired' selection for ALL the wires that pass through the event structure?
initialize ALL your shift registers with empty arrays/strings
then wire all shift registers through the event structure, irrespective of that data being used in the event or not.
the terminals on the event structure still show the 'use defualt if unwired' selected.
also, how many event cases do you have? do you have event cases for all the boolean controls?
Is it possible to post the vi (in lv 2010 or lower) and not the document? we can try it out here and see what could be the solution.
Regards
Freelance_LV
TestAutomation Consultant
Message 15 of 15
(846 Views)
