event structure with control refnum
does anybody know if it is possible to use the event structure in a subvi with a control refnum of the mainvi?
For example the subvi includes a while loop with an event structure which should stop the iteration when the event "stop button value changed" in the mainvi occurs.
Thanks in advance,
Alexandra
(2,736 Views)
Not quite yet, though it sure looks like something that might become
possible.
For the moment, you can only respond to events that are for the front
panel of the diagram that holds the event structure.
Greg McKaskle
(2,736 Views)
