event structure
Hi, I have two events in a event structure. I need to use one event to input "yes" to a boolean indicator and use the other event to inpot "no" to the same boolean indicator. How to do that? The Labview help is helpless.
Message 1 of 9
(4,566 Views)
Use a local variable.
@Jerry Jin wrote:
[...] The Labview help is helpless.
Definitely not. It may take some time until it becomes your friend.
Message 2 of 9
(4,562 Views)
Like this?
Message 3 of 9
(4,561 Views)
I'm a bit confused by the idea of a boolean with values Yes an No so I assume you meant property.text
Here's a quick example that demonstrates the event structure
Message 4 of 9
(4,558 Views)
@WayneS1324 wrote:
Like this?
Wayne!  Hold up on that- event structures without a loop are pretty dangerous. The events can queue up pretty fast waiting for an active event loop.  And we won't use the run continusly button outside of code testing again!
With a while loop thats a nice example
Message 5 of 9
(4,551 Views)
@Jeff Bohrer wrote:
@WayneS1324 wrote:
Like this?
Yeah, I know. It was just meant as the simplest possible example of an event structure. I guess it was a bad example.
Message 6 of 9
(4,546 Views)
Could you save the VI as LABVIEW 2009 version so I can open it?
Message 7 of 9
(4,535 Views)
Accepted by topic author Jerry Jin
Here you are-
Message 8 of 9
(4,527 Views)
Hey, I'd really love to get the same for LV 7.0 Smiley Happy
Would be really great!
Thanks in advance,
logi
Lv 7.0 Sudent Edt. Mac OsX 10.6.8/10.7.2 Windows XP
Message 9 of 9
(4,471 Views)
