event structure
How to develop a coding that will count the number of arrow key presses using event structure in Labview?
(3,896 Views)
Its fairly simple. Did you read the tutorial about the event structure? I would recommend doing that instead of suggesting a solution to your question.
(3,887 Views)
While Loop with an Event Strucute in it and a shift register to keep track of how many times somebody pressed the arrow key.  You will want the Key Down event.
(3,860 Views)
