event structure
Hi Guys..
            I have a very simple question.. but some how I can’t get my head around it.
            I have two types of buttons.
                        A push on Type A button will sent number 123 to the next module
                        A push on Type B button will sent number 987 to the next module
                        Both type of buttons exits on one tab (same case structure)
There are total of 8 tabs.
                        There are 50 Type A buttons, gets pushed all the time.
                        Only 2 Type B button ( type B is a dial), Type B button hardly every get pushed.  Only once a while..
Here is how I did it.. but I think its very inefficient!!
            In the Tab ( same case structure ), I placed a event structure.
                        Event1 type A button pushed, sent 123 out to case structure, through case structure, goes out to next module.
                        Event 2 type B button pushed, sent 987 out to case structure, through case structure, goes to next module.
Problem
            Then adding a new event, I have to manually add 50 buttons to that one event… and this is just painful!!  And I think its dump way to do it.. in C all I have to do is,
            If (type B ==push)
                        {out = 987;
            else {
                        out = 123}
see.. 5 lines.. not even..
Pelase help
(3,534 Views)
Please attach your program.
Do you possibly have multiple event structures, one for each tab case? That's not good. Maybe I misunderstand?
Instead of individual buttons, use a 2D array of buttons (or a cluster of buttons). Now all you need is an event for the array value change. If needed you can add some code to determine which button was pressed.
(3,530 Views)
I will try using a cluster  but.. I thought if I use a 2nd array then I can't have different buttons..  that is all the buttons has to have the same caption.
(3,508 Views)
