event structures and while loops
I have a program that uses event structures to look for mouse click events in the ui. I also want the program to poll a hardware switch and watch for a relay to close. Someone on this board suggested that I have my polling loop throw a flag when the relay closes and have my event structure look for that flag.
I have a polling while loop next to my event structure (both are inside a large while loop to stop the program). But it seems that my event structure never triggers. I watched with the highlighting on, and I just went around and around in my polling loop, even when an event should have triggered. My guess is that I shouldn't have the while loop next to the event structure like that, but I can't think of how I should structure it.
Thank you.
Kasey
(3,108 Views)
Hi Kasey
You should have your event-structure in one while-loop and your polling in one while loop.
If you have both in the same while loop, in the first iteration the polling-loop is started and runs until stopped.
Your flag can be a dynamic event. Just have a look at the examples included in labview.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,107 Views)
Thanks. That seems to work.
Kasey
(3,089 Views)
