event structures with relay switches
I would like to have a program that watches for a relay switch to close and then executes a subvi. I was hoping to use an event structure that triggers off the relay switch...is that possible? I don't see any hardware showing up in the list of events. Otherwise, how do I go about monitoring the relay switch? BTW, the relay is in the same cPCI chassis as the computer running Labview.
Thanks.
(2,860 Views)
Hi
What you will most likely have to do is to define a USER event associated with your relay switch in order to launch the subvi.
here's an example on NI website;
http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=E0CA7D39AD4B54DDE034080020E74861&p_node=DZ52054&p_submitted=N&p_rank=&p_answer=&p_source=External
Cyril Bouton
Active LabVIEW Developper
(2,855 Views)
Thank you for the suggestion. I am not familiar with user events, but I looked at the example you suggested. However, I can't figure out how to associate a user event with a hardware trigger. Does anyone know how/if I can do this?
Kasey
(2,842 Views)
You need a digital input device to read the switch. You could use a cheap USB DIO (around $100), or you could possible use the parallel port. You would have to poll the DIO or the parallel port periodically (in a while loop, with a 100mSec timer). When the input value changes, you would wire the value to a Value(signaling) property node of some boolean. The event structure can contain an event of that boolean's value change. When the switch was made or opened, the event would fire.
- tbob
Inventor of the WORM Global
(2,835 Views)
