example program forces front panel screen size
I am somewhat of a novice at LabView programming.  I used an example program as the starting point.  I expanded the front panel, added buttons and displays, and added code to do additional things.  But when the program gets to the example code, it forces the front panel screen down to its original (example) size.  The help messages talk about going to File > VI properties > screen size but none of the settings solve the problem.  The code that I wrote starts with a full screen front panel and runs fine until the program gets to the example code then the front panel shrinks.  There must be something in that portion of the code that is setting the properties.  Anyone know what is happening?
(4,046 Views)
try posting your code so we can look
_____________
Creator of the BundleMagic plugin for LabVIEW!
(4,039 Views)
Hi Gary,
You already answered that on your own:
All you have to do is find that part of code!
Start searching using breakpoints and step-by-step execution (aka basic debugging techniques)…
(4,020 Views)
I have attached the vi.  I will start trying to debug.
(4,006 Views)
I haven't been able to test this properly because I am missing a lot of the VIs but when I was loading the missing files I did notice that there is a 'svx_Set Panel Size.vi' called. I might recommend that as a good place to start looking. Search for it and delete it and see what happens.
(3,995 Views)
That did it!  Thanks so much for your help.  The set set panel size command was hidden in an "INIT" connection.  Thanks again!!
(3,964 Views)
