examples of BCM 2835 together in one??
I have run 2 examples together in VI with ROi3 & LabVIEW.
Write mask & MCP3008 Example SPI, my requirement is to make a VI which reads channel 8 of MCP in Single Ended" with setting plus in VI & I want to control the other GPIO pins.
Switch in a PIN LOW & high for switching OFF/On of LED.
This programme channels 8 data on LabVIEW & GPIO pin connecting with LED & also Switching OFF/On with button.
The problem, running OK but when stopped the RPi3 gets disconnected without any errors
Can some look over the VI.
Message 1 of 1
(2,277 Views)
