excel dynamic vi not executable
When creating an executable of my application using report generation I add the excel dynamic vi's to the project and also to the dynamic vi section.  After building the application I get the following error:
Possible Reasons
An included VI or one of its dependencies does not exist. Open all  Startup/Exported/Dynamically called VIs, recompile them  (Ctrl-Shift Click the run arrow), and save them to update their dependencies.
C:\Program Files\National Instruments\LabVIEW 8.0\vi.lib\addons\_office\_exclsub.llb\_Excel Dynamic VIs.vi
Details
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 7 occurred at ABAPI Dist Report Read Link Info Error.vi -> ABAPI Dist Cmp Settings to Disk Hier.vi -> ABAPI Get Settings From File.vi -> EBEP_Invoke_Build_Engine.vi -> EBUIP_Build_Invoke.vi -> EBUIP_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux.
NI-488:  Non-existent board.
Tried recompiling with no luck.  Attached warnings file when opening excel dynamic vi.
(4,090 Views)
Have you already looked at this:
http://digital.ni.com/public.nsf/allkb/86256A47004E16D186256A84004CB883
I followed these instructions for a similar problem with WORD and at
the end they worked.
regards
(4,086 Views)
Link no longer seems to be available, anbody know where that information now exists ?
(3,886 Views)
(3,870 Views)
Thank You 🙂
(3,864 Views)
