excel exe
I want to read and write values in excel file, i have used activex control for that.
it is working fine on developement PC with application exe, microsoft excel installed, but when i transfer it to a PC where excel is not installed then it is not working properly as read and write.
please let me know if i am missing anything.
regards
shrek
(3,452 Views)
You can't access excel if excel isn't installed on the computer. You can also read and write excel files using ADO, then you don't need excel. But there are limitations - like the arrangement of the data in the file.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,444 Views)
ActiveX is used to communicate between programs, if the other computer does not have excel installed then the ActiveX communications will not work!
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(3,442 Views)
Yes you are missing library file for excel when you build your application
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,434 Views)
