excel graph y-axis lable Orientation
Can anybody explain me how to do the Excel graph Y-axis label orientation.Can anybody provide the Code for this.
Thanks in advance,
Srinath.
Message 1 of 10
(3,116 Views)
Hi srinath,
                     Open up NI_ReportGenerationToolkit.lvlib:Excel_Set_Scale.vi and expand the Axis class to show more properties.
I got an attachment and there you can see the Orientation property.I hope this helps.And if not give a further more explanation.
Thanks as kudos only:)
Message 2 of 10
(3,113 Views)
Hi Danil,
Tried the same way but  "unknown system error 97" i got can you tell me how to overcome this situation.
Message 3 of 10
(3,106 Views)
Hi srinath,
              Check you included the application in the excel vi's library, that you will find in the labview directory addons
Message 4 of 10
(3,101 Views)
Hi Daniel,
Can you explain me bit clearly,
Thanks for your quick reply.
Message 5 of 10
(3,096 Views)
Hi srinath,
Can you post the complete error description?
The error could have many sources, many of them possibly linked to YOUR specific machine:
- Depending on Excel/LabVIEW version (reproducable on machines only having the same Excel/LabVIEW version)
- Certain settings (reproducable only on machines using the same settings, so you got to provide those)
Message 6 of 10
(3,091 Views)
Hi Daniel,
I am using Labview Version 10.0 and Microsoft Excel 2007 .
Error is :
Unknown System Error in File.vi
Error code is 97.
Possible Reason :A null or previously deleted refnum was passed in as an input
Message 7 of 10
(3,085 Views)
Hi srinath,
The error description is  "A null or previously deleted refnum was passed in as an input."
Run your code in highlight mode. See where exactly you are getting error.Please check if you are closing any reference and using that Invoke node later in your code.
And If you can please attach your code.
Message 8 of 10
(3,074 Views)
Hi Daniel,
I Dont have permission to attach file.
I am getting the error at invoke node here reference is ActiveX class Graph.Axes
 Taking the Excel_worksheet reference from the Get ActiveX References.vi. This is reference  for the invoke node selecting OLEObjects method ,
Activating the object the object output i am passing to Varient to data typre vi, Here data type is ActiveX reference as Graph.Axes.
Output of that reference is giving to Invoke node item method ... Here i am getting the error.
Message 9 of 10
(3,065 Views)
Hi srinath,
                 Please see this link:-
                 http://forums.ni.com/t5/LabVIEW/Error-97-using-Active-X-property-node/td-p/334978
Message 10 of 10
(3,062 Views)
