excel graphs
I have  numerous excel files with data and graphs.  What I will need to do is to create an excel spreadsheet with just the graphs from those files and as many files as I choose.
How could I import just the graphs from those files?  excel macro? report generation toolkit? active x?
Any suggestions would be greatly apprecitated.
Brian
Brian
(2,770 Views)
Hi Brian,
You're definitely going to want to use ActiveX to control Excel from LabVIEW.  We have many documents and example programs to get you going that you should check out here:
http://zone.ni.com/devzone/conceptd.nsf/webmain/4d86c9752c658da78625689300730c10
and here's a search that will get you started on some example programs:
http://search.ni.com/nisearch/nisearchservlet?nistype=default&ddown=3&cluster=true&filter=%2Btaxonom...
Give those a read and hit the links and see if you can steal from any of those examples.
mike
(2,740 Views)
