excel headers and timestamp required
Hi I am working on labview 7 express and using a fieldpoint device to get signals.
I am using the express vi. write file to spreadsheet at the moment and I was wondering How I could go about:
1) Adding headers to each of the columns
2) Have a separate section with a timestamp on it.
I know that I can't do alot of things using this express vi. so I was wondering how I can go about doing this using sub vi's.
Could you please attach image files instead of the actual Vi's because version 7 doesnt open up anything higher than 7.
Kind regards,
Message 1 of 12
(5,145 Views)
What I would suggest is that you follow the instructions on the block diagram to make a copy of the function that accepts string arrays as inputs. Then you convert all of your data to strings. You can call the function twice - once for writing the header and again for the data if you repeatedly write data,
p.s. Write To Spreadsheet File is not an Express VI.
Message 2 of 12
(5,140 Views)
Hello Mr Knutson could you perhaps show me how to do this? via an image file I am still quite lost.
Kind regards,
Attached is my VI for your reference.
Message 3 of 12
(5,135 Views)
Hi scho,
Do you have report generation toolkit?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 4 of 12
(5,133 Views)
sorry no Labview 7 doesnt come with it I think.
Message 5 of 12
(5,131 Views)
Kind regards,
You are using the Write to Measurement File (which is an Express VI) and not the Write to Spreadsheet File (which is not). I would suggest the later with the modification I mentioned. Otherwise, you can modify the channel name attribute to get headers of your choice. There have been numerous posts on the subject such as this one
Message 6 of 12
(5,118 Views)
Hey,
You are using the express VI for LVM writing .. below figure explain about header and time stamp setting..
BR, HS
Message 7 of 12
(5,104 Views)
Hi scho,
See the folder attached with this post.
You will find image of code in which I have shown how to fill excel cells(image "2")...
Also Images 1 7 3 will show you how to get references.
I have also attaches vi. It is in Labview 8.5
If you want you can downconvert it from some one. I can not do it in labview 7
I hope this will help you.
Best of luckSmiley Happy
Gaurav k
CLD Certified !!!!!
Message 8 of 12
(5,091 Views)
I think I replied to this Q in another thread... but here is the vi I use all the time.
Simply feed it a single dimension array containing the measurements for each line in the Excel file, if you don't wire the time stamp input it add it's own.
BTW: Unless you are trying to do something fancy an "Excel file" can be as simple as a text file with commas as the delimiter (.csv) or tabs (default .xls)
As for headers you simply write the headers to the Excel file before you start your acquisition loop
=== Engineer Ambiguously ===
Message 9 of 12
(5,072 Views)
Hello gak thank you for your patience...
What you have shown me in your images is no good for me because I dont have excel application for some reason.
Is there an alternative method of doing this?
Kind regards,
Scho
Message 10 of 12
(5,000 Views)
