excel headers
I simply write my headers and any other information to the file before I enter my acquisition loop.
=== Engineer Ambiguously ===
Message 11 of 16
(1,568 Views)
hi gak could you please show me this vi in an image file?
Kind regards,
Message 12 of 16
(1,546 Views)
Hi scho,
Which vi are you talking about?
I have already posted image of vi which calls template.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 13 of 16
(1,543 Views)
Sorry gak,
 I am working on labview 7 express and using a fieldpoint device to get signals.
I am using the express vi. write file to spreadsheet at the moment and I was wondering How I could go about:
1) Adding headers to each of the columns
2) Have a separate section with a timestamp on it.
I know that I can't do alot of things using this express vi. so I was wondering how I can go about doing this using sub vi's.
Could you please attach image files instead of the actual Vi's because version 7 doesnt open up anything higher than 7.
Kind regards,
Message 14 of 16
(1,540 Views)
Hi scho,
I will reply to your original post.
Otherwise you will get few solutios here and few there...Smiley Sad
So it will be easy for you to refer single post.Smiley Wink
Gaurav k
CLD Certified !!!!!
Message 15 of 16
(1,529 Views)
Here is a vi I use all the time.
Simply feed it a single dimension array containing the measurements for each line in the Excel file, if you don't wire the time stamp input it add it's own.
BTW: Unless you are trying to do something fancy an "Excel file" can be as simple as a text file with commas as the delimiter (.csv) or tabs (default .xls)
Message 16 of 16
(1,514 Views)
