excel one graph multiple types
    I would like to display two data series in a single Excel graph.  One series needs to be a smooth XY line with no markers and the second a XY scatter with no lines.  Currently I am using the "Easy Excel Graph" VI.  However this VI inserts an additional graph when used multiple time.  I also thought of using the "Excel update Graph" VI, but there is no terminal to define graph type.
(2,894 Views)
I tried this out in LabVIEW using the "Excel Insert Graph.vi".  I was able to plot two signals on one graph in Excel, but I could not find a way to make one linear and one scattered.  Apparently this is not an option within any of the Excel Graph VIs.  What you can do, is select one of the signals after the graph is imported to Excel and change the format there.  I will go ahead and file a product suggestion for this.  Thanks!
(2,866 Views)
