excel read and write to labview
can anyone help me.
I have these following problems:
1. how to save my FFT graph into data?
2. how to get my data after tab delimited it into excel file from labview?
Henry
Message 1 of 14
(5,330 Views)
    In trying to open your file there are a large number of sub-vi's that aren't in the standard distro. Could you do a "Save with options",
"Development distribution" and send the resultant ".llb" file? As far as what you are trying to do, without seeing your code I will hazard a guess. If your data is in the form of an array, either 1D or 2D you can send it into the "Write to spreadsheet file" found in the "File I/O" pallette, read it back in with the matching "Read from spreadsheet file". Both of these functions allow formatting the data and the read returns a 2D array.
Arvin Sloan Jr.   😉
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2 of 14
(5,318 Views)
hi!
this is the saved data i get. i don't understand other things you want me to do. sorry i'm a newbie here, pls. have patience. tnx.
actually i'm using labjack as my hardware that's why i'm using their vi's.
Message 3 of 14
(5,311 Views)
To show what LV_Pro was saying, here's what he mentioned to use.  Have a look at the picture...  use those vi's to write to a spreadsheet file.
Message 4 of 14
(5,307 Views)
Thank you Novatron but i know that already, but what i don't understand what LV_Pro said is to make "Save with Option" and :"Development Distribution"
Henry
Message 5 of 14
(5,289 Views)
Hi Jack,
please deliver the complete SUB VI structure to make anyone able to test it.
File - Save with options - development distribution
Regards, Hacky
Message 6 of 14
(5,283 Views)
there you go...thank you for a clear instruction.Smiley Happy
Message 7 of 14
(5,282 Views)
Hi Jack,
since i didnt have analog data acquisition i modified the missing AI part (which is located in vi.lib
to give me an array of 4 x 600 random numbers to get it work.
ok, i see that you acquire continously data. when you put this to an .csv file you will get a lot of ffts.
is it this you want or do you want a snapshot of your fft at a time?
regards hacky
Message 8 of 14
(5,279 Views)
actually the data i'm saving is in time domain, i want to save in FFT, can i save my data in frequency domain? if i can how do i do that? and also how to use the read spreadsheet vi and write spreadsheet vi? tnx..
Message 9 of 14
(5,276 Views)
Hi Jack,
i prepared a small demo showing how to handle FFT and Spreadsheet files.
Take care because my setup is german. we have comma instead of point.
good luck, Hacky
Message 10 of 14
(5,271 Views)
