excel report change sheet name
iám using the report generation toolkit with LV8.5.1 and Excel. How can i change the name of the sheet?
greetings
schwede
(3,674 Views)
(3,672 Views)
But i don`t use low level vi`s. I use the report generation toolkit, where can i get the reference?
(3,668 Views)
You don't require low level Vi. You just have to work with property node and invoke node using activeX.
choose Select ActiveX Class > Browse.. option. Select the Type Library as Microsoft Excel 11.0... & the Object as _Workbook.
It ll automatically fetch you the Excel_Worksheet reference as the data.
Message Edited by Ranji on 07-02-2009 06:02 AM
(3,659 Views)
Can ypu please send me a short image of it.
(3,653 Views)
Hi Schwede,
you can make it like this (see the attachment).
Mike
(3,646 Views)
