excel save as
This is a 2 part question:
1. I have a VI that writes data to excel but i want to leave my original file intact and save as different name, i keep getting an error
2. for the new name i want to append a timestamp but cannot find how to get the PC current time
any help would be appreciated, i've attached the VI and a sample spreadsheet
i'm using LV 2012 and office 2007
(4,428 Views)
Check your filename.  You have some '/' which are invalid characters.  Remove the random number generator...not necessary.
aputman
(4,423 Views)
Here's one way to generate the PC date and time string.
Ben64
(4,418 Views)
Accepted by topic author at2bob
Simpler way
Ben64
(4,413 Views)
thanks, got it working
(4,368 Views)
Good afternoon,
How do I write values from a chart in labview to Excel by pressing a button in labview ? When i press another button the stop to grab values.
In the final the values stay in directory when i can consult.
I would appreciate help please.
FASP
(4,293 Views)
You could always drop a property node to get the values from the chart and then write to a csv file.  Or, you can also always right click on a chart in LabVIEW and choose to export to Excel.
Jesse S.
(4,252 Views)
