excel spreadsheet control for 64 bit windows OS
Hi all,
I'm looking for a way to use excel (or something equivalent) in a 64 bit labview application.  I've been using OWC11 in a 32 bit application to allow users to take advantage of most excel functions and build a table that is used by the application to run a test.  I'd like to keep using it but it can't run in a 64 bit application.  I haven't been able to find anything similar for 64 bit, so unless someone knows of something, perhaps someone could suggest another method?
(3,623 Views)
Accepted by topic author gharris
Hi gharris,
I have included a link that shows how to perform basic tasks in excel using ActiveX in LabVIEW.  Is this something that would work for your application?
Using LabVIEW and AcitveX to Perform Basic Tasks in Microsoft Excel
Justin D.
(3,590 Views)
Thanks Justin,
I didn't realize activex was available in 64bit OSs.  I think I'll be able to build my application based on that example.  I wish I could run excel as a front panel object, but I'm hoping that if I can watch out for excel-user problems like excel being closed in the middle of a labview operation, I should be just fine with this.
George
(3,561 Views)
