excel
hello,
i have data stored in a table ( 2 columns) which i would like to use in excel.
what is the best way of doing this?
- maryam.
(2,811 Views)
Hi maryam,
you can use the report generation toolkit to create an excel file. You can also use the activex functions directly. You will find more information about it here.
Hope it helps.
Mike
(2,810 Views)
You can also simply write out the file using Write To Spreadsheet File which creates a file that can be opened in Excel. It won't be an Excel workbook, but it will be a text file that can be opened in Excel.
(2,800 Views)
