excracting different sized arrays from each iteration of a for loop
Hi everyone,
I have a nested for loop inside another for loop. The interior for loop sorts through a set of data and picks out certain values and places them into an array. How can I isolate these different sized arrays after each iteration of the outer loop? any help would be apreciated
alex
(2,523 Views)
Hi alex,
you can use array of cluster of array. With this combination it is possible that all arrays in the cluster have a different length.
Hope it helps.
Mike
(2,517 Views)
I agree with Mike.
Using an array of a cluster of arrays is your easiest solution.
R
(2,507 Views)
