exe and front panel
Hello everybody!!!
my program consists graphically in controls, indicators, charts inside a tab control. How can I see only the  the tab control without the space that's around in the file exe? The tab control has the exact dimensions for the screen of a net book ....and i want only to visualize it...without space around...
thank you very much..
GM
(2,148 Views)
You just need to set the tab control to be the dimension you require.  Then set the size of the front panel window to match.
(2,129 Views)
