exe hanging on a right click in a tree control
source code is running smoothly.But when its exe is operated ,the application is getting hanged when I try to get the shortcut menu of a tree child by right clicking on it.what may be problem?
Regards
A.Aneesh
(2,928 Views)
Can you attach you code or a block diagram of your vi?
(2,919 Views)
find the vi attached
(2,874 Views)
Hi azdxd,
The VI you attached is so large, and missing so may subVIs, it is going to be very difficult to figure out the issue you have brought up.  Can you simplify and isolate the issue to one small VI that can be built into an executable.  If so, we can take a look at that and figure out what is causing your "hanging."
Cheers,
Brian A.
(2,856 Views)
Sorry but i agree with brain.I am not able to make out anything from your vi.
(2,823 Views)
