exe icon left on toolbar after app is closed
I have built several apps and their installers and all execute fine and all but one closes correctly.  For one of them the icon stays on the toolbar but clicking on the icon doesn't reopen the app.  This does not happen when I open and close the source VI, only for the exe version.  I can't spot any obvious difference between the build for this VI and the other builds I have done.
Denis Kohl
(2,702 Views)
It looks like there is still a VI in memory. In LV8.x you can see this by setting up a debug-connection, if you have debuggin enabled in your build and you start a debug session from a development envirenment you can see all VI's in memory.
Ton
My LabVIEW Ideas
(2,695 Views)
That's a good idea, Ton. Along those lines, I'd check for any dynamically called VI's (through VI server or a toolkit such as Report Generation). Is there any kind of I/O involved or some other shared resource we should be aware of? FYI - to enable debugging in a build specification, put a check in the "Enable debugging" box under the "Advanced" category.
Hope this helps,
Charlie S.
Visit ni.com/gettingstarted for step-by-step help in setting up your system
(2,676 Views)
