exe installer for 32 bit windows
hi all, i've made an exe installer with labview 8.6 in a computer with windows 7 (64bit)
When i try to install it in a computer with windows xp 32 bit, i can't do it
i have this message: (attached)
How can i do to make it work?
Message 1 of 8
(6,542 Views)
Did you use 64-bit LabVIEW to create this VI or 32-bit LabVIEW?
It doesn't matter what version of Windows you used.  It matters what version of LabVIEW
Message 2 of 8
(6,527 Views)
hi ravens fan!
i've just checked .is the 64 bit labview.
is there anything i can do?
Message 3 of 8
(6,515 Views)
You need to build your app in 32 bit LabVIEW.  Is there any reason you used 64 bit LabVIEW?  There is generally not much reason to use it unless you need the extra capacity for large memory applicaitons.
Message 4 of 8
(6,501 Views)
no reason. is the one i have. i'll try to download de 32 bit labview, i'll tell you what happens asap.
Thanks.
Message 5 of 8
(6,497 Views)
Dear RaevensFan.
I´ve been working this days in the project.
What is happening to me now, is that when I try to run the project with the LV 2012 32 bit, every part of the Daqmx code does´nt work.
i´m ataching the same code with different version of LV.
I´ve tried downloading the daqmx drivers, and still does´nt work.
What do you think is the problem?
Message 6 of 8
(6,441 Views)
I wish I could see your text file.
(Not having office installed)
Message 7 of 8
(6,435 Views)
The DAQmx drivers aren't installed for LV 2012  (as seen by all the broken wires and missing DAQmx VI's in the LV 2012 screenshot).
Have you installed the DAQmx drivers after you installed LV 2012 32 bit?  What version is the driver?
Message 8 of 8
(6,425 Views)
