executable does not stop running when closed
You unregistered for the user event, but you did not destroy it.  What happens if you put the destroy events in there also?
Message 11 of 22
(2,265 Views)
I removed the shift register for the events because it was giving an error. I destroyed events as well and unregistering, but still have the problem.
Message 12 of 22
(2,259 Views)
OK in a thousand words-
Message 13 of 22
(2,251 Views)
That makes sense.
I tried making a change, but it's still not working. It does use a global variable setup. Could something along those lines cause the problem? Is there a way to check to see if there are loose ends somehow?
Thank you for your help!
Message 14 of 22
(2,243 Views)
The left loop looks rather dodgy.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 22
(2,242 Views)
/Y
I have now removed that loop entirely for the purposes of debugging. Any method of closing closes the front panel, but the thread continues to run.
Message 16 of 22
(2,241 Views)
Thank you all for your help. Through your suggestions, I've isolated the problem to having another .vi in the build. Even if I do not activate this event, just having it built with the .exe causes the application to not terminate when it's closed. In other words, even if I open the the application and immediately close it, it will not terminate.
How can I call on another program but not have this problem?
I've included the stripped down, very simple program.
Thank you!
Message 17 of 22
(2,233 Views)
Wait till august?
Whoops- LabVIEW cannot launch another process and leave it running.  You COULD take the same vi referance and kill process on it through Windows.  Why did you "start it" if it cannot be controled?
Perhaps dynamically launching a vi you have no controll over was a poor discision.  Timeout the dratted vi or enable dynamic events in it to close when your app exits
Message 18 of 22
(2,225 Views)
@Jeff Bohrer wrote:
Wait till august?
At least in the non-executable form, this method of passing between programs poses no problem.In the executable, the problem occurs even if the event case that triggers the dynamic launching is never activated. Simply by having the application present somewhere in the code seems to cause the problem.
 I want to be able to open a second .vi from this initial program (remember it's goin to be packed into an .exe). Is there a better way to do this than a dynamic reference?
Message 19 of 22
(2,221 Views)
Just make sure you have the Close reference in the Quit event? I'm not sure, but it feels like it should solve the problem. 🙂
/Y
Qestit Systems
Message 20 of 22
(2,212 Views)
