executable doesn't run sub-panels
Hi all!
I have to write a labview program that runs multiple VIs depending on what the user wants. Thus, in order to be able to test individual VIs if something goes wrong I constructed an event handled structure with a tab controller. Each tab controller has a subPanel which points to a VI that I need to control from the main panel once the app is running. Everything goes perfectly until I build the executable when everything is loaded to the main, but I cannot control anything! (I keep pressing the buttons, but they don't activate anything). All buttons control one event in my structure (i.e. control DC motor, record measurements, stop measurements etc)
In the image attached, there's an example with my VI which controls a power supply for a DC motor. It's supposed to be controlled by the 'Set voltage' button and every time that button is clicked the user can just update the voltage until they are satisfied. However, despite the fact that in the main labview VI everything works, the executable does nothing!
Any idea what i may be missing/doing wrong? How are we supposed to use supPannels in order to work in an executable?
Thanks for all the help anyone can provide!
simm01
Message 1 of 9
(7,567 Views)
Accepted by topic author simm01
The compiler doesn't understand path constants in this context. You'll need to "always include" them in the build, or, replace them with a Static VI ref, in which case they'll automatically be included in the build.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 2 of 9
(7,553 Views)
I can't use the first method as for some reason it doesn't let me select other VIs than the main one when building the executable.
I tried the static reference method, but this time I can't even see the VI and the buttons don't work again. Is this how I am supposed to use a static reference? (see the 2 jpeg files attached)
Message 3 of 9
(7,538 Views)
Hi simm,
VI needed for "always include" when building an executable have to be part of your project!
When something doesn't work you should check error messages/wires. Until now you don't do so…
Message 4 of 9
(7,524 Views)
You should use the error cluster and it will help you figure out what is going on.  Instead of using VI Path, use VI Name.  When you specify the name of the VI as a string, LabVIEW will load the VI in memory.
Message 5 of 9
(7,523 Views)
Thanks everyone! I added the individual VIs to the project and used static reference and everything is working now! Smiley Happy
Message 6 of 9
(7,497 Views)
I have a quite complex project that requires me to have multiple executable running.
My problem is as follow:
MAIN.exe need to load in a sub panel any of the other.exe.
All the exe has been compiled in labview. The main.exe come from a diferent project than the other.exe.
In labview everything is working.
I can access sucessfully the control and indicator value of the other.exe trough vi server.
Using the same VI reference, should work in the sub panel. But why it is not working?
Benoit
Message 7 of 9
(6,732 Views)
Hi Benoit,
main point: executables use all their own memory space. You can use VI server to communicate between executables.
Beside of this: how do you load executables into subpanels?
Message 8 of 9
(6,727 Views)
well you teach me nothing there...
As what I can see, if your vi is in a different executable, it is impossible to put this vi in a sub panel. so I create a "duplication" of this vi without the code and I apply the control and indicator property. the other solution I found is to exchange data trough VI server as well and then apply those to the vi in the sub panel.
Benoit
Message 9 of 9
(6,671 Views)
