executable exits at startup
I have ran into an issue where I hope I can get some support from the forums.
Many (but not all) of built executables crash on startup. It seems to be newer builds that crash. (i.e - I have yet to come across an older executable that don't work)
The funny part is - I can load the code just fine and run the VI , but as soon as I (or anyone else) build it it just does not start. For a while I suspected comport drivers (as this machine is one giant USB/serial driver conflict) but; I just tried building an "empty" vi with just a while loop and blinking bool and that still does not start (as built executable - it works fine when I run it)
The executables go into the taskbar, sits there for a few seconds, then dissapears. No errors are shown.
I have uninstalled and reinstalled NI-run time, NI-VISA, patched Labview to 2012 SP1, uninstalled a lot of weird drivers I have collected over the years, but, obviously, to no effect.
Where do I look next?
(3,644 Views)
It could be because of corrupt installation of 'Application Builder'. Can you repair the 'Applicaiton Builder' (or preferably complete IDE, LabVIEW and its all toolkits/modules)??
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(3,638 Views)
Thanks for the reply, but as mentioned, I can't run executables others have built.
But yes, A complete reinstall might be the path ahead.
(3,625 Views)
What is your processor model?
(3,621 Views)
Intel Core2 Duo P8700
(3,589 Views)
