executable file for IMAQ VIs
You need both the LabVIEW RTE 2011 and the Vision RTE installed on the PC you want to run your application on.
And you need a license for the Vision part.
Show us what you have done so far.
We can only guess right now as to why it is not working for you.
Show us how you have setup the installer, and what software part are installed on the target PC (Use MAX or something like that).
Message 11 of 14
(1,108 Views)
I finally able to create the installer for that program and now it is running properly in w/o LV machines with a message that it is evaluation version and needs to be activated. I thinbk it will run for 30 days in a machine w/o activation.
so now it is a bit okay with me. But, after running the program I closed it and switched to other works. Now if I want to run the .exe again how to do so. Because installer has already installed all the LV components required. But I am not getting the executable file link anywhere in the computer.
Please let me know the way using which user can run the exe file after installing the installer.
Message 12 of 14
(1,094 Views)
When creating the installer, you can define shortcuts to your installed exe file and also select where to places these shortcuts.
Otherwise you have to manually locate your exe file to run it.
Message 13 of 14
(1,088 Views)
Thank you
Thanks to all of you.
Message 14 of 14
(1,085 Views)
