executable opc connection
Hi all
I-trying to build an executable which reads values from a RT-target (cRIO) and then sends this data to an opc-server.
I managed to read the values from the rt-target, but unfortunatelly the connection to the opc seems not to work. I created a library with the opc Server and the variables in the project. if I run the vi on the pc with LabView installed everthing works fine. Also if I try the executable on this pc. When I change to the other PC where I want the executable to be running. The programm runs with no error, but the data never gets to the OPC-server.
Has somone any idea why this happens?
Manuel
(3,362 Views)
Hi Manuelwaser,
your problem sounds like an configuration problem.
It would be helpful to post your build-specifications or your project without VIs.
Here is an guide for ...
Building an Installer (Windows) - LabVIEW 2011 Help - National Instruments
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/build_installer/
How Do I Use OPC in LabVIEW? - National Instruments
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MwxSAE&l=en-US
Over that you'll need the DSC RUN-Time System:
What is the DSC Run-Time System and When Should I Use It? - National Instruments
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LRUSA2&l=en-US
(3,301 Views)
