executable to call external dll with error
    I am developing an application to control a spectrometer via an external dll(in C++). When running in development environment, it is fine.
After making an executable, the executable always gives error of call function. The problem seems in finding the external dll. Although I defined the path, the default value of the path is the location where the dll is.
To avoid the problem, every time before run the program, I need to define the path by clicking the browse button then run the program. But the default value of the path is exactly same as the actual path. I wonder why every time I have to browse the dll file. It would be grateful if somebody can give advice.  Attached is my simplified application(Labview 8.2) to call external dll
    Thanks.
   Guang
(2,720 Views)
I think your problem comes from the configuration of your Call Library Function Node. Please find here some information about it and particularly pay attention at ‘Specify Path on the diagram’.
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(2,707 Views)
