executable windows sous linux
Bonjour,
y a t'il un moyen de lancer un programme labview compilé sous XP, sur une machine Linux?
Via un émulateur windows sous Linux, le run-time engine ne veut pas s'installer...
Merci d'avance,
- Lionel Poisson -
(3,310 Views)
just a translation...
Is it possible tu run a Labview compiled program with the  XP version, on a computer working under Linux?
When I try to install the run-time engine with an emulator, it does not want to work
Thanks in advence,
- Lionel Poisson -
(3,309 Views)
No it's not. You would need to buy the LabVIEW for Linux version, copy the XP files to the Linux box, fix any problems, use the app builder in the LabVIEW for Linux version to create an exe, distribute this new exe with the Linux version of the LabVIEW run-time engine
(3,303 Views)
What about all my dll that I compiled (under XP) and used by my LabView program. Will I have to rebuilt everything to have the program working under Linux?
Sincerely,
- Lionel Poisson -
(3,277 Views)
