executable
Hello to all!
I have a problem: I created a vi with the corresponding executable, on my PC on wich windows 7 is installed works perfectly, but if I transfer the setup on other PCs with XP or VISTA works very slowly, why? To create the installer I also added the VISA RUNTIME ENGINE 5.3 to read data from an external instrumentation...
Thanks!!
GM
(3,928 Views)
Define "slowly". I assume it actually works correctly, just slower.
Do the other computers have significantly less ram? What else is running (security software, spyware, etc.)
(3,907 Views)
The program runs "slowly" means that it works but with a great delay (15 sec for each operation). I think it isn't a problem with RAM because I've tested it on another pc with more RAM than mine (8GB vs 4GB).
GM
(3,874 Views)
Does "delay" mean that if pressing a button, the reaction is displayed about 15s later?
Did you already check system parameters like CPU load and RAM usage using Windows Task Manager/Performance Monitor?
Norbert
Norbert
Expert: Geometry
(3,858 Views)
Yes! my exe works only on Windows 7...in the addiotional installers I've checked NI-labview Runtime Engine 2011 and Visa Runtime 5.3...(I've Labview 2011).
Thanks!
(3,849 Views)
Post some code. Otherwise we are simply guessing. We have not encountered any similar issues and we release our tools for both XP and Win 7. I suspect it is something specific in your code.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,818 Views)
