executable
I have a new project in which one server and three clients, I am planning to create executable vis only for clients  .Server will be haing shared variables so what are the license that i have to procure as NI is having wide range of licenses too much confused
san
(3,142 Views)
It sounds like you just need the RunTime Engine, which doesn't really need a license.  But I would go have a nice talk with your local NI representative to make sure.
(3,123 Views)
You need a license with which you can compile executables, typically Professional or a separate Application Builder. A few modules (as vision) requires a license on each target, but anything you can build with a Professional license requires no license on the targets.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,106 Views)
