execute batch file having gmake command
Hi,  I am executing batch file having gmake command in it, when i run batch file directly it works correctly,
but when i try to execute it from LabVIEW using system Exec.vi
i got following error,
process_easy: DuplicateHandle(In) failed (e=6)
process_easy() failed to launch process (e=6)
Thanks in advance
(3,131 Views)
What OS?
How are you calling it in LV?
What is in the batch file?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,100 Views)
