executing all levels of a stacked sequence structure at the same time
I have a vi that has 5 seperate 'tabs' in a stacked sequence structure. I'm needing all 5 tabs to be executing and collecting data at the same time, not just when one tab is active. It's being used to control a test table, and one of the tabs is a data collection tab, which needs to pull current values from three of the four other tabs constantly. Any help would be appreciated.
thank you,
J. Morgan
(2,543 Views)
The only point of a sequence structure is to execute sequentially. If the frames could execute in parallel, it wouldn't be a sequence structure;). You could have your code in five different while loops or in five different subVIs (with no data dependency between them) in the same frame of a sequence.
(2,538 Views)
If the code is a simple "run through once" type code, you could place 5 single frames on your block diagram and link them with a single wire input. Take a constant or a control and connect it as an input to your 5 frames to use as a software type trigger.
Also, understand that unless you have multiple processors your code can never execute truly "simultaneously"...but more of a time-slice execution where the CPU does pieces of each operation in order.
-Brett
(2,515 Views)
