execution/exit of DIO single read/write.vi
Hi all,
System - Windows NT4.0, LabView 7.0, PCI-DIO-96 card.
Info -
I am using the "DIO single read/write.vi" to update ports on a custom board. The Labview code has an outer For Loop that executes 64 times (to update the ports 64 times). Inside the loop is a sequence structure. The first sequence frame uses PPI B Port A of the DIO-96 in output Mode 0 (no handshake) to update one target port. The next frame uses PPI A Port A in output Mode 1 (handshake) to update a different target port. The DIO PPIs are always used in the same Mode and the same data direction.
Question 1 -
When the vi executes, does it look at the iteration input and leave the PPI config register alone if the iteration input is nonzero? Specifical
ly, during my system init routine, the input is wired to the iteration terminal of the For Loop. Later in the code (after exiting init) the vi is used to do updates in other structures. I want all subsequent executions of the vi to be the same configuration as initialized. If I tie a nonzero numeric constant to the iteration input of the vi during subsequent executions, will the vi leave the 8255 in the same configuration as when the init routine was exited?
Question 2 -
I need to wait for the handshake in the second sequence frame to complete before the sequence is exited. I assume that when the vi is used inside of a sequence, it is analagous to a subroutine call. Does the vi wait for the handshake to complete before returning? In other words, will the vi complete the handshake with my target port before the sequence frame is exited? If not, any suggestions on how to wait for the completion?
TIA - Charlie
(2,549 Views)
Charlie,
Yes, if the iteration input to DIO Single Read/Write.vi is greater than zero, configuration will not take place. Furthermore, the VI will only return once execution has completed.
Good luck with your application.
Spencer S.
(2,549 Views)
