execution without click on run button
I'm new in programming with Labview.
I want to design a system that since input variables change, the output must change without clicking on run to start.
thank you
(3,392 Views)
Accepted by topic author mahdouch
Put your code in a while loop.  Add a Wait function so the loop does not consume all the available CPU resources.
Look at the on-line tutorials for help getting started with LabVIEW.
Lynn
(3,383 Views)
... and once the program is ready to be deployed and used by others (non-programmers), set it to "run when opened" and potentially built it into a standalone application.
(3,367 Views)
Thank you for your helpful responses;
(3,338 Views)
