exiting program after text file is created
i want to close labview using the exit.vi after the text file is created....also i am using c++ to execute the labview application is there anyway to make sure labview finishes its routine in c++ before i send the text file to a motion controler
the c++ routine to open the exe is
int main()
  system("start C:\\greg\\g.exe");
  return 0;
then the digital i/o command woudl execute
anyone know what i can do before sending a digital line to tell the motion control software to pick up the text file?
thanks
(2,812 Views)
the digital i/o has nothin to do wiht labview ...i am basically using c++ to control a frame grabber and saving a bmp then using labview to open that bitmap and process it and send it to excel.. thanks
(2,807 Views)
Given the amount of time it takes for LV to launch, you would probibly get better response time if you let the LV code run in a loop watching a predefined "input" directory for new files to process, and writing its results to a predefined "output" directory. The code that uses the text files would likewise sit in a loop waiting for a new text file to appear. (BTW: what will that other piece of code be written in?)
Alternately, if you don't like the idea of polling a directory, make the main LV application event-driven with a user event that performs the processing. Then create a small VI that you run from your C++ code that simply fires that user event.
Finally, given all the limitations of C++ perhaps the most straightforward solution might be to write the whole application in LV?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,782 Views)
