experience with Metrohm Dosimat driver?
I try to communicate with a Metrohm Dosimat 665 using the Mmds665.llb for Labview 6.1. However, I get a timeout, probably because the Dosimat does not set the handshake as expected. Has anyone tested the driver sucessfully or had a similar problem and solved it?
Any help appreciated
Sylvester
(3,676 Views)
Accepted by topic author sylvester
Hi sylvester,
could you post your VI? Did you download the driver from the following link?
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E93ED659CE034080020E748...
Here it says that the driver could be used with LabVIEW 8.0 and later.
Best Regards
(3,633 Views)
I know that it's an old post but I trie to communicate with the 665 dosimat with this vi and i had a "line error".
This post is mark "resolve" so maybe can you help me.
(3,103 Views)
