ā06-13-2007 08:56 AM
ā06-13-2007 10:31 AM
ā06-13-2007 10:55 AM
Sorry, maybe I didn't explain well what my problem is. I know that to estimate the damping and the amplitude of the exponential curve the Exponential Fit VI uses a logarithmic scale and fits the line using the linear regression. Now, what I would like to know is if the linear fitting is going to minimize the chi-square as the General LS Linear Fit VI (for example) or not. If it is like that I can understand the meaning of the SD and the resulting fitting it will be weighted.
ā06-15-2007 04:38 AM
ā06-15-2007 09:40 AM
laser,
I'm not too familiar with what each function does on the lower levels, but the help document that tells us the formula that the VI uses to calculate the residue. If you scroll down in the context help, you can see a line that reads "The VI calculates mse using the following equation.", which is followed by an equation.
This is all I can offer right now, but I am going to check around the department and see what I can find. I appreciate your patience.
ā06-15-2007
10:01 AM
- last edited on
ā06-27-2026
03:33 PM
by
Content Cleaner
ā06-15-2007 10:16 AM
Thanks mseserve.
I already tried to compair the fitting using different VIs. I used the Exponential, Linear and General LS Linear Fit VI and I was surprise about the very good results obained with the Exponential Fit VI. For this, I was curious to understand what really happens in the Exponential VI. Anyway, now I discovered that one of my co-worker has LabVIEW 8.2 and infact I'm thinking to try the Exponential Fit and to test the different kind of methods available with this VI.
One thing, can I install LabVIEW 8.2 without remove the older version? I would like to keep the LabVIEW 7 for now (just in case....)
Many Thanks
ā06-15-2007 10:23 AM
