export data from plot to excel appends "m" or "u" to data
Sometimes when I right click on plot and select export to Excel, the data in Excel has "m" or "u" appended, meaning 1.0E-3 or 1.0E-6. But I can't get Excel to recognize these as numbers.
Is there way to export in different format or to get Excel to recognize these numbers?
Thank you
(1,462 Views)
Accepted by topic author tony_wash_gx5
Hi Tony,
Can you define "sometimes" more precisely? When exactly do you get those "u"/"m" chars?
Just a(n educated) guess: are you formatting the axis values to show SI units (%p)? If so: why do you wonder about getting such values when exporting to Excel?
Sure: don't rely on built-in methods of the chart, but create your own routine to export data to a CSV file! It's quite easy: you need just one file function...
(1,450 Views)
I guess you're formatting your strings with %p? Use %f, %g or %e (see the documentation).
%p formats numbers to strings with SI prefixes.
(1,427 Views)
Do a search and replace of m -> e-3 in excel 😄
Qestit Systems
Certified-LabVIEW-Developer
(1,405 Views)
