export graph image
i need to export the graph image using as a file or clopboard, .... using method right click -- graph-- export simplified image..
i created a installer and i installed with another system when i export simplified image to clipboard it will crash the window then labview application will close down..
when i checked withe core software its working well.....
Balaji DP
(3,167 Views)
I believe this is the same issue as this. If so, this bug has been fixed in 8.5.1.
(3,144 Views)
