export simplified image invode node
I would like to export an image of just the plot area in a xy graph. I have tried get image invode node, but get the gray boundry of the graph. The export image invoke node works better, but the gridlines are too many and too dark. I don't want to turn them all off which is an option in the node, but rather display only major axis lines, or perhaps change their color to a light gray (which is what they are on the front panel).
thanks!
(5,012 Views)
Hi trneb,
you can hide the gray frame of the graph by painting it in development enviroment to transparent. In the blockdiagram you can change all bg colors, so that the image is for example with a white background. See the example. I hope it helps.
Mike
(5,001 Views)
Thanks alot,
I used the auto tool switching feature so much i forgot about the set color tool! Setting the gray to transparent did the trick.
(4,995 Views)
