export table to excel
Hi
plesae see example that I send , its export data from table to excel file and save the excel file in c:
the main problem I have number with 20 digit and other number with 15 digit , when I save and open in using excel the number look as
8.9972E+19 and other number is 3.596e+14
I need to see the number in full format as its look in the table
89972010311041561435
359628040266996
how can I do that
(3,807 Views)
Without looking at the code and excel file, it sounds like the formatting of the cells within excel.
If you right click the cell and select format, you can change the format of the number
(3,803 Views)
Hi
I want to do it in labview code , is there option that way
thanks
(3,800 Views)
@Elyan_wisam wrote:
Hi
thanks
Sure there is a way. Learn ActiveX. There are examples that ship with LabVIEW.
You'll need to read the relevant sections of the Excel Developer Reference for the version of Excel you have.
I have linked to Excel 2013 version http://msdn.microsoft.com/en-us/library/office/ee861528%28v=office.15%29.aspx
(3,792 Views)
