export to website
Mike, I have less experience with Labview, and no experience at all with http request operations.
There is nobody that can help me in this matter in my immediate environment.
So thank you for your help.
Message 11 of 13
(912 Views)
If you just want to have your VI as a web page, you can also use the remote panel option. This does require the LabVIEW runtime for each user. You can also build the VI into a web service. Lots of different options.
Message 12 of 13
(903 Views)
Jancan: It is an array of POST data to submit to the server. You need to build an array of your key/value pairs of data you want to send. I believe only the name/value fields need to have anything in them unless you also want to send files.
(blog)
Message 13 of 13
(871 Views)
