export wave file from diadem
Dear all,
I'm trying to export wave files from Diadem. Data has been sampled with LabView and stored in an LVM file. I have the GfSWave.dll properly installed following the instructions of the help file. When trying to export the data, how do you select the channel in the pop up window???
finally, the following error message occurs.
regards, David
(2,775 Views)
Hi David!
It all depends on the Verion of Diadem you are using. Since Diadem 9.1 there are Data-PlugIns (see link).
www.ni.com/dataplugins
There you can download the Dataplugin for *.wav format and load the data without any problems in Diadem.
Greetings, Mona
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(2,752 Views)
